F4 Fork on a F3 - need Help
On my F3 the rebound adjuster is jammed. Its cheaper to buy used forks than to buy new adjuters (about $170 each). I want to research putting a F4 fork on my F3. This would give me bigger calipers and a compression adjustment.
I need someone who owns a F4 to measure the length of the fork from the axle centerline to the top of the fork tube (not including Preload and rebound adjusters).
The reason I want to know the length is I want a fork with the smallest geometry change.
I know the triple tree would have to change.
Thanks
Thanks
I've already done this for you in the same post you made in the F4 section here...
https://cbrforum.com/forum/cbr-600f4...ion-f3-129669/
driyac
07-11-2010 02:40 AM
civicblade
04-23-2009 08:24 AM
