Engine "coughing", robbed of air?
Recently while I was out on a test ride, after changing my air filter, my engine started to make a bad sound. It was about a mile away from home when my engine started to sound like it was "coughing", a cylinder was misfiring, or like the engine was being robbed of air or gas. I towed the bike home and checked my air filter change (fine). Then I tore into my spark plugs. On one of the coils there was rust, and on another was oil. The plugs themselves looked fine (for 13,000 miles). But, I decided that I should change out the plugs to hopefully fix the problem (plus I already had the old ones removed). I haven't done it yet (going to get iridiums), but does anybody have any suggestions? Basically, do you think it could be the plugs or is it OBVIOUSLY something else?
02 F4i w/ 13,000 miles
Another note about the engine noise: it consistantly sounds like the engine can't get air or gas at all parts of the rev range. And the sound is VERY loud.
Thanks,
Andrew
Thanks,
Andrew
RE: Engine "coughing", robbed of air?
It started happening a mile AFTER I let it warm up. I was just sitting at a stop light, in neutral, when it started freaking out. I don't think it is related to the air filter, I think it was just a coincidence that I had changed the filter before. Also, I checked all my lines to make sure there were no kinks in it. Any ideas?
thanks
thanks
