Electrical short under gas tank causing smoke...
was removing the gas tank for some body repairs and while pulling the return line somehow the tank shorted on the subframe and smoke was a riseing!!! i freaked pulled the tank up put it into its stock postion and pulled the bat cable....should of done this first i know.... so i figured the worst the pump is fried. yet i pluged it in turned the key and fuel shot out WOOHOO right? idk im freaked should i look elsewere for a issue did i just get lucky...? just need input thx u
