dynojet pcIII downloads
RE: dynojet pcIII downloads
I've got the same setup as you do, and I can tell you that you won't find it on the web! I contacted Dynamax and they sent me the following info:
With only a slip on, selecting an alternate map is not a problem. Exhaust tuning is done in the header pipes, not the silencers. Being that all slip ons, no matter what brand, slip onto the same stock header, makes it so the maps can be interchanged. You can use 108-007 for the micron slip on and it will work great. Canadian and US bikes are the same.
Thank you,
Curt Schannen
Dynojet Research
Technical Support
(800)992-4993
By the way, how do you like the Akra? Did it affect the performance of you bike? What year is your F4i - mines an '05 and it's throttle response is smooth as silk without the pipe. I've just installed the Akra, but haven't tried it out yet! I've pretty much come to the conclusion that a Power Commander is unnecessary.
Regards
Amnesia[/align]
Thank you,
Curt Schannen
Dynojet Research
Technical Support
(800)992-4993
Regards
Amnesia[/align]
