Dynojet ignition module
Who has one? I have the LCD display and PC3 so if I get one can I switch back and forth with maps of the ignition also? Ride to the track fill up with race fuel and just switch maps? How much do you advance the ignition when running different fuel? Is this worth the $300 or should I put it toward full exhaust?
RE: Dynojet ignition module
you can't just tell how much you need to advance, it should be dyno-tuned on the race fuel to get most of it.. i'd say exhaust will net more useful ponies both on the track and on the street
I'd rather get the quick shift kit than the ignition module.
I thought you had to get the ignition module for the kit to work?
ORIGINAL: Todd84 I thought you had to get the ignition module for the kit to work? |
ORIGINAL: apkraven ORIGINAL: Todd84 I thought you had to get the ignition module for the kit to work? |
Some do, F4i doesn't.
Thank you very much! the shift kit will be ordered next week. If I would have know that I would have ordered it for the company drag outing on tuesday[sm=headbang.gif]
