Dyno numbers??
They are the runs that Arrow perform during their testing phases,
note they are DIN
The main bit I like is the 4250 - 6000. notice that the flat spot is almost gone and added by 4-6 hp, this I can feel in the real world, the bike does not need a fist full to set off.
It is so smooth. I can set off and the accel is pulls all the way with no slow bits,
When you look at the pipe close up you can see that they are works of art,
From the headers the pipe is conical in shape and the link pipes are in a higher postion, then after the link pipes again they expand in a gradual conical shape.
they meet under the bike and again it is a concical shape to the muffler, The 4 into 2 into 1 postion is moved so that they are in a differing place.
All these little changes make the differnce between a slip on and a full system. You really have to see the detail to appreciate it.
I would have no hesitation in spending this money again for the ridability that I have gained. This is how the bike should be from the factory!
note they are DIN
note they are DIN
