Dropped bike - help....
I had a Truck cut me off earlier this week and I grabbed way too much front brake and ended up doing a stoppie.. but laid it down... on the left side..
I had my luggage on the back so there was no damage to the rear end at all.
The bike landed directly on the stator cover and the woodcraft frame slider...
The stator cover did have a small crack in it and it leaked oil.. so i replaced that.. I also noticed that the left foot peg brack was bent in a bit and the gear shifter linkage was touching the chain... that has been replaced..
Other than that - I dont see any other damage... - I am just worried I bent the frame.. it seems to track fine.. doesnt seem to wobble..
Would Hitting the stator cover and frame slider that hard cause the frame to bend? -
Also what is the possibility that the engine could be damaged? - it seems to start fine and I feel a little vibration at high RPMs - but for the life of me I cant remember if it was like that b4... I think you always felt some vibration at high RPMS... just paranoid.. now I guess..
I do notice that the Left side frame slider doesn't protrude as far as the right.. maybe a 1/4 inch difference.. however i believe it was like that before... Does anyone have any experience with these? or could check their bike for me..
Thanks again - I love my F4I - just hate to see it totally screwed by such a little fall..
Well the faster you were going the higher the probability that the damage is more extensive than you think. However, I think it's pretty unlikely that you compromised the integrity of your frame. Motorcycle frames are pretty tough.
As far as your frame slider being further in, it is possible that it dented the frame when the bike went down. But as long as it's not severely damaged I think you should be alright. How fast were you going when you went down?
Have you double and triple checked to make sure everything else is in good condition? A vibration could be coming from anywhere. My advise would be to find a smooth road that you're familiar with and see if it still persists. Definitely something worth looking in to.
Good luck with everything! Maybe get some pictures of the frame slider and post them up here. It's hard to give solid advice when you can't see what's going on.
I didnt see any coolant in the oil... or vis versa -
The vibration I am getting is just a little buzz.. in the handlebars.. at 9k+ rpm - its not shimming or shaking.. - just a little buzz..
I believe everyone gets that no??
Speed I was going maybe 20 mph... and was basically at a stop when it went over.. but from my recollection.. I was pritty high in the air..
Ill get some pics and post.. soon
