Does this sound like battery or R/R?
Old 09-20-2011, 08:16 PM
jeffjones's Avatar
Default Does this sound like battery or R/R?
Battery or R/R?
So recently the last couple of days i have been driving the dash goes dim and at lower rpm's you can feel the bike stuttering. So I find a hill and turn the bike off and it won't cranked back up, So proceed to roll down the hill and jump it and it runs fine for the next little while, but has happened almost everytime I ride it the last 2 days.
Weird thing is if I let it die then jump it and drive for just a minute I can come back hours later and it will fire up.
Battery gets about 12.8V ignition off and about [email protected]
If anyone has had this happen a point in the right direction will be quite helpful.
Cheers
Old 09-21-2011, 05:11 AM
MadHattr059's Avatar
Easy way to start is take the battery to be load tested to sears, auotozone, etc.
After that, check out these links...
http://www.triumphrat.net/speed-trip...r-upgrade.html
https://cbrforum.com/forum/f2-tech-9...-solved-27739/
Ern
Old 09-21-2011, 06:01 AM
Old 11-07-2011, 07:18 AM
jeffjones's Avatar
Just so this isn't left un answered.
I changed the battery and it the problem still happened, So I put a used Rectifier in and the bike works perfect now.
Old 11-07-2011, 05:27 PM
cool, thanks! Nice to hear the closure, too. helps with the database in my head on symptoms vs cause/solutions. ;-)
Ern
Old 11-07-2011, 07:04 PM
jeffjones's Avatar
Ern
Yeah I try to close my threads with an answer as there are so many times that I find the same symptoms and a bunch of people at guessing what the problem is and no solution.
estate4life
12-04-2012 11:08 PM
michasiek
04-01-2010 12:22 PM
jharbinson
12-31-2009 09:23 AM
njdjh2o
04-11-2008 07:20 PM
ampfp
04-07-2008 02:22 PM
Quick Reply: Does this sound like battery or R/R?
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
