Does this sound like battery or R/R?
Battery or R/R?
So recently the last couple of days i have been driving the dash goes dim and at lower rpm's you can feel the bike stuttering. So I find a hill and turn the bike off and it won't cranked back up, So proceed to roll down the hill and jump it and it runs fine for the next little while, but has happened almost everytime I ride it the last 2 days. Weird thing is if I let it die then jump it and drive for just a minute I can come back hours later and it will fire up. Battery gets about 12.8V ignition off and about 14.8V@4000rpm. If anyone has had this happen a point in the right direction will be quite helpful. Cheers |
Easy way to start is take the battery to be load tested to sears, auotozone, etc.
After that, check out these links... http://www.triumphrat.net/speed-trip...r-upgrade.html https://cbrforum.com/forum/f2-tech-9...-solved-27739/ Ern |
Just so this isn't left un answered.
I changed the battery and it the problem still happened, So I put a used Rectifier in and the bike works perfect now. |
cool, thanks! Nice to hear the closure, too. helps with the database in my head on symptoms vs cause/solutions. ;-)
Ern |
Originally Posted by MadHattr059
(Post 1112060)
Ern |
