Do you top off your gas tank?
Whenever I fill up, I usually put in gas until it reaches the very top of the compartment, but I noticed that some of you may only fill up to the little bar in the gas tank or whatever. Is there a certain reason for that? I'm not sure if the owner's manual actually states where to fill your gas tank to.
I know that in cars, I never "top off" because gas expands in heat, so I always fill up till the nozzle clicks.
What about you guys? Anyone else fill up all the way to the top like I do and has had any problems?
Same. When it hits the bar, I'm satisfied.
Edit - from the owner's manual: "Add fuel until the level reaches the bottom of the filler neck. Avoid overfilling the tank. There should be no fuel in the filler neck."
Btw, once I was trying to slowly squeeze the trigger on the nozzle to top of my gas tank when I accidents squeezed too hard and gas got into the filler neck. I saw it funnel out through that little drain hole though. I'm assume there is a tube that leads the excess gas down to the bottom of the bike, right?
