DIY keyless ignition
has anyone done this and if so how?
im converting my bike to a dedicated tracker and my ignition is mangled. |
Wouldn't be hard to track the wiring from the ignition and run it through a switch instead. Download a manual with a wiring diagram and have some fun.
That would be hella-cool!
Wouldn't you be able just to by pass the ignition module off the key? Just route it throu a kill switch. So no one can just jump on and go.
All the track bikes i've seen have done this, you just bypass the key and use the starter to start it up
google is not my friend:icon_doh: i tried searching at a few forums and google but all i came up with is it a no problem job and use a rocker switch. but i was hoping there would be some tutorial but alas i will do it and make a tutorial:icon_idea:
