DIY Angel Eyes
I love that do you have any pictures from different angles? Also what did you use to make this? I love that look and that is very similar to what I was wanting to do. I want mine to act as blinkers as well because with my flush mounts on coming traffic cant see if I am turning. Thanks for any info.
"I love that do you have any pictures from different angles? Also what did you use to make this? I love that look and that is very similar to what I was wanting to do. I want mine to act as blinkers as well because with my flush mounts on coming traffic cant see if I am turning. Thanks for any info."
you can, mine are hooked up to the remote system for the shows, but if you can hook them up as markers and flashers. when you use your turn signals the marker lights in your turn signals actually go out. if you hook a relay to the positive flash wire and run it to your leds it will make them flash. run the leds from your marker lights and have a secondary wire for the flash. i also noticed the audi's do the same thing
