Dire need of front end pics!! Also speedo help!
Old 03-25-2012, 11:29 PM
donnygeewebb's Avatar
Default Dire need of front end pics!! Also speedo help!
Hello all! Those of you may know my bike from the previous threads I posted regarding my current project, my 01 f4i. The whole front end was garbage and I need to get a detailed picture of the fairing stay bracket itself, and where the headlight mounts to the stay bracket. I would really appreciate it if anyone could do this for me. The manual pics SUCK!!!
Also, a few days ago I went to turn my bike on and i noticed that i wasnt getting the fi light, or the tach counting down like its supposed to. It just gives me the time, and whenever i plug it in, it counts down, just not when i turn the key on. It does run fine, im just not getting anything from the speedo. Any help is really appreciated!!
Old 03-27-2012, 10:53 PM
Update on the speedo. It will occasionally come on when im riding and i hold down the shifter slightly, and also with the brakes. ANY HELP!?!?
Old 03-29-2012, 02:17 AM
96shox's Avatar
speedo cuts in and out? Most likely the speedo sensor. not too bad to replace, just need a bunch of extensions and small hands
Old 03-29-2012, 08:15 AM
Do you think it could be a loose connection? If so where would it be loose at? I've read on a few threads that it was loose connections but I can't find where it plugs in. Do you have any pics?
Old 04-03-2012, 04:47 PM
96shox's Avatar
speedo sensor is on the left side of the engine block sitting right on top. This is what it looks like but obviously only the top part is outside the engine block.
Old 04-03-2012, 05:09 PM
Speedo sensor is the same on most honda cbr's. Im useing a sensor off a 2000 rc51 and it works fine and is direct bolt-up. I remember having a hard time finding one for my f4i so its just a small help out. (100% known fit is rc51, bolt on and plug is the same)
Old 04-03-2012, 05:55 PM
Okay, I'll check it. But Ive read somewhere it could be a bad ground? where is the ground for the speedo?
Old 04-03-2012, 07:05 PM
Everything that has power has some sort of ground. On honda the ground wire is green, its not the usual black wire.
Old 04-03-2012, 07:53 PM
Is it straight green? or with a stripe?
Old 04-03-2012, 11:24 PM
Solid green.
FireBlade910
07-28-2015 10:57 PM
adamw89_2000
07-23-2010 05:24 PM
honda f4
01-27-2009 01:57 AM
bakesteak
07-29-2008 02:09 PM
L8X
03-21-2005 06:59 PM
Quick Reply: Dire need of front end pics!! Also speedo help!
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
