Crazy problem
Ive found some other people posting having the same problem on other forums but theres never any resoultion to it.
ok when i say its an ecu prob i dont neccesarily mean that the ecu itself is bad but since it starts the ignition on sequence (counts down speedo, flashes lights, ect) and pauses with the light indicators that means it has either A) identified a problem(sensor out of norm) or B) ecu is faulty ( possibly made its own code conflict or lost part of its programming or "fried"). the reason I'm going with this instead of (example: BAS) is you said you started it, it ran, and then had this problem the next start. nothing about taking it apart, dropping it ect. but hay, anythings possible. I just wish i couldve let you know to scratch your initials in the old one not that the shop just cleans it resets it and charges you for a new one and 4 hours labor for a 20 min job. hope everything works out though so you can get back on the road.
I have read of this problem before.
The OP did solve the problem a few years ago. However i dont remember what exactly it was.
IIRC there was a problem with a short, near the fuse box area.
The main relay for most of the lights are in the fusebox there for the cluster.
Thats the only place i would think of where everything would go haywire
anywhere else would just pop fuse. Have a look there first and let me know what happens
