A couple questions regarding temp and vibration
Old 05-14-2010, 10:52 AM
Default A couple questions regarding temp and vibration
I'm fairly new to my F4i (2006, 3300 miles). I went for a couple hour ride on the highway through some twisties with a friend who rides a gsxr1000. I noticed that my right hand was going numb and that my bike vibrates pretty baddly through the bars. Is this engine notorious for vibrating? I ride a cr250r that vibrates too, but this one gets to me after a while.
Another question regards my temperature getting way high. My friend and switched bikes for a bit and we stopped to switch back we left our bikes idling. The bikes were probably running for 2 or 3 minutes before we got back on them. Mine was showing 247 and was creeping higher, so i quickly took off to get the temp down. My friend figured my fan isn't working. His 1000 gixer was sitting at a constant 219. Riding down the road my bike rests at 173 or so. I guess i'll have to let it kreep back up and check the fan. Is this high temperature normal for these bikes?
Old 05-14-2010, 11:04 AM
July 2010 ROTM
yeah 247 is way high, mine wont get higher than 225-thats when my fans kick on and it starts cooling down pretty quick, also, on my bike i dont notice any vibration, definitley not enough to make my hand numb. sry i dunno what the cause could be
Old 05-14-2010, 12:33 PM
F4ith's Avatar
Does your bike have bar ends? You can try looking into some vibration reducing bar ends.
Lol not trying to sound douchy, but your friend figured your fan wasn't working and didn't bother to check/listen for it?
Old 05-14-2010, 02:18 PM
My bike just has the stock metal bar ends on it, and my shorty 2 bros pipe is way to loud to hear a fan. As far as i know the previous owner didn't do any mods besides a pipe and cosmetic things. The motor on my bike vibrates away at almost all rpms. I already did the cam chain tensioner so it's new, but my bike runs like new and is practically new some i'm guessing this vibration is somewhat normal?? My friends gsxr didn't vibrate like this thing. Can anyone else help?
Old 05-14-2010, 03:43 PM
When my hands start going numb i remember to loosen my grip and the problem goes away.
Old 05-14-2010, 05:37 PM
Kuroshio's Avatar
247 = 3 degrees Fahrenheit shy of overheat. Yes, you have a problem. Check your fan then check your coolant. When was the last time it was flushed (or even checked)?
As far as the vibration, assuming nothing is wrong with the bike then its your posture. If you're supporting your upper body with your arms on the bike, you turn your arms and wrists into shock absorbers. All of the vibrations from the road are going to travel thru your hands, up your arms and thru your body. And if you're tight on the bars, you're fighting the bike's self correcting nature.
Old 05-14-2010, 06:09 PM
kowen1208's Avatar
Do you notice vibration anywhere else besides through the handlebars? If not, it's probably your posture. The GSXR may be different enough that you have a different riding position and don't feel those same vibrations.
If your pipe is too loud to hear the fan, get the bike up to temp and let it idle until it gets up above 225. Then cut the engine. If your fan is working, it should remain on until the temp is back down, your turn the key to off, or your battery dies.
southpole560
10-28-2011 11:17 AM
2fast4you
01-09-2011 02:44 AM
roldaphat9
07-18-2007 10:43 AM
Praetor
03-16-2007 02:26 AM
DerBarbarian
05-02-2006 03:26 PM
Quick Reply: A couple questions regarding temp and vibration
Featured Sponsors
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
