cooling fan
So the blade on my fan broke and now i cant ride. Can i just buy the blade or do i have to buy the whole fan with the motor? cause the motor still works.
the blades are sold seperately
but there has to be a reason why they broke, the last one i saw with broken blades had a cracked housing by one of the mounts so when you bolted it in it would twist and cause the blades to rub and eventually break |
Funny you post this... I'd never once heard of anyone having the cooling fan blade break, then mine broke this past tuesday. The little center piece broke off the blade and stayed on the motor... probably the same as what happened to yours
You can indeed get the blade seperately.... I ordered mine on wednesday from the local Honda dealer for $45 with tax, and it arrived today. Got it installed and works like a champ I figured the plastic just fatigued over time, being right there in the heat and all |
Same thing happened to me. The center piece broke off and the fan stopped working. Ended up going on ebay and I got a used motor and blades for $40 bucks shipped. Works like a champ now.
You can still ride, just don't sit there and idle for too long lol
is there some kind of a metal bracket to install in the center to protect the plastic from melting? i had to replace the fan one time because the blades melted and i dont want to do it again.
yea there like a bolt that hold the fan then the the blade and then the little metal bracket. When i took it off you could tell that it was melted. I just ordered the blade from honda and it will take about three days to get it. Should i have orderd anything else?
Originally Posted by draudt
(Post 797518)
im pretty sure that any honda dealership will have it. Does any body know where i could buy a used fan motor? Im going to sale my bike in the spring to get a newer one and I think the motor is pretty much shot. It started to make a strange noise when it turns on
damn man. i threw one away not too long ago. the fan was broken but the motor worked :/
anyway, look on ebay. i got the whole fan assembly for $30 shipped. |
