Coolant leaking..any ideas?
RE: Coolant leaking..any ideas?
i got the prestone 50/50 prediluted...is that ok to use??
Don't hold me to any of that but I know BMW cars FREAK out with regular antifreeze. My guess is the silicates may tear up the water pump or react with the aluminum. I'd just use the Honda stuff or Distilled water untill I figure it out.
ORIGINAL: fishfryer527
There's a lesson to be learned there - Don't fill your bike with blood...
FWIW... our bikes use the same radiator cap as a Honda Accord, or probably any other Honda car. I know mine is the same as my car, lol. I had a small rip in the seal on my bikes cap, and everything was closed so I yanked the cap off my car and sure enough... exactly the same. Been on there for about 4 months now, works perfect
I believe Honda motors are not to be used with silicate inhibitors, green prestone (not the extended life)may have silicates. I am not 100% sure on this but I believe our bikes want organic acidinhibitors, not silicates. Maybe someone can confirm this.
Interesting that you'd mention BMW'sbecause they're sealed systems. Not sure what year you're referring to though.
Jaybird,
What year are you referring to when you say that a BMW cooling system is a "sealed" system. I have not seen a "sealed" cooling system on a BMW ever. I am a BMW mechanic so I feelfairly comfortable saying that NO american BMW has a "sealed" cooling system.
A sealed system means that you can not add to it. A BMW has an expansion tank that you can add to. In fact it is where you add all the coolant and the radiator pulls from that. The radiator itself can not be added to, but that does not make it a "sealed" system, because you can add to it through the expansion tank.
Don't take this as an attack. I am not trying to **** anyone off. Just trying to share info on a subject that I know about.
Sadly, Yes you have been mis-informed. They may have told you that speaking only of the radiator, which would be some-what correct. You cannot add to the radiator. You do however have an expansion tank which the radiator pulls from when it gets low. When you drain the coolant you add to the expansion tank. Then while the car is running you bleed the system and fill to the proper level.
