Coolant Flush Procedure
Old 03-09-2007 | 06:36 PM
Cry For The Devil's Avatar
Default Coolant Flush Procedure
I tried searching this site for a "how-to" guide on flushing your coolant. I'm looking to flush the coolant from my '03 CBR600 before I get it ready for the track. What's the easiest/best procedure to follow? I was thinking of disconnecting the lower radiator hose close to the engine to drain most of the coolant, then flushing rest of the old coolant through the top of the radiator with a garden hose. Is this correct or is there a better method? Thanks.
Old 03-10-2007 | 05:50 AM
vasta101's Avatar
Default RE: Coolant Flush Procedure
I disconnected the hose from the radiator to the water pump at the water pump and let it drain. Then i just stuck a garden hose (which didn't have any type of fitting for a nozzle so it fit perfectly) into the water pump and turned it on until i didn't see any more green... I tried several ways to do it and this seemed to be the easiest...
Old 03-10-2007 | 06:23 AM
Kewl Breeze's Avatar
Retired Moderator
ORIGINAL: Cry For The Devil
...then flushing rest of the old coolant through the top of the radiator with a garden hose. Is this correct or is there a better method? Thanks.
I wouldn't use mineral or tap water as it can eventually corrode your system. I've always used distilled on all my bikes ... it's cheap and safer.
Make sure to thank Abad for making an excellent and easy to follow "How-To" Guide
How To Flush Cooling System Guide (Click)
Old 03-10-2007 | 07:48 PM
Thanks for your input guys, I was starting to think that CBRForum was snubbing me!
Old 03-11-2007 | 03:50 PM
christhek's Avatar
Good post for an awesome procedure. I will be using that info in the next couple of weeks on my bike.
Old 03-11-2007 | 04:13 PM
pochop7's Avatar
That is a good post, I will definetly be doing that to my bike very soon. Thanks for the How-to guide
Old 03-24-2007 | 10:45 AM
snobrdrdan's Avatar
Well that just made my day!!
thanks guys
Old 04-24-2007 | 10:23 PM
hondadriver4life's Avatar
just read this and yeah this is gonna be very helpfull in the next couple days lol
oh but for the record (an di know it sounds dumb but i like to beprecise lol) what wioll i have to do different for the 1000rr?
Old 04-25-2007 | 01:53 AM
FiremanE4's Avatar
YEah thanks for the post, been wanting to do this to my bike as it sat for quite some time before I got it. Also need to drain the brake fluid, change the oil, lube and tighten chain!Have a rainy day project, now just need a rainy day!.
Old 04-25-2007 | 01:31 PM
snobrdrdan's Avatar
If you're using the Honda (pre mixed) coolant or adding regular coolant (like Prestone or something) to the bike you might not wanna flush it with water
I say that because you won't be able to get all the water back out of the engine and that could throw off you mixture ratio of coolant & water.
I think the guys that worry about flushing it with water (to get all the coolant out)are the guys that are going to the track and just using water (& water wetter)
Quick Reply: Coolant Flush Procedure
