Clutch Lever questions
I parked my bike very close to the garage wall last week and forgot the kickstand before getting down, and caught my bike as it fell on the wall.
The only damage I did was clutch lever bent down slightly.
Bike shifts and runs great but that bent clutch lever feels weird and also feels like I don't have to let it out as much as before.
So I was looking for a replacement, and I see prices from less than $20 to more than $100 and was wondering what is the difference between click, folding, click-n-roll, etc. Some of them have this 1-2-3-4 adjustment setting, my OEM one does not, what does that adjust?
I am not looking for anything fancy, does anyone know where I can buy the OEM ones?
Also, while replacing the clutch lever, do I have to do anything with the clutch cable? I have read on some forums that Yes, and some say there's just one bolt and no need to do anything to the clutch cable.
An oem style replacement lever can be had in the low end of your price listing. Remove pivot bolt, unhook cable, place a little grease on the new lever pivot, attach cable, replace pivot bolt, you're done. You may need to adjust the engagement point with the new lever by using the cable adjuster on the lever housing. If you run into any problems, post it and someone here will jump in to help.
