clutch lever
Hey guys. I'm having an issue with the clutch lever. The screw that seems to hold it in no longer stays tight and after about 15 or 20 minutes of riding it's pretty much fully unscrewed. Has this happened to anybody else and if so how did you fix it? Is it really a big deal bc i can normally just hand tighten it on the road. Any advice???
Matt |
RE: clutch lever
do you have a nut on the back that holds the screw in place?
RE: clutch lever
Exactly what I was going to say! Bought my bike used and had same problem. Checked out my friends bike and his had a nut on it. Haven't had that problem since. If your bike DOES have the nut then I would try some loctite. (mind out of gutter on this one)
RE: clutch lever
maybee a lock washer would help??
