clutch install (f4i)
RE: clutch install (f4i)
When you take it apart, just keep in mind to watch where the judder spring goes, along with it's orientation. This will also show you the clutch disc that is different. Sometimes theres two discs that are different from the others, so just be on the lookout. Not much different from dirt, except for the size..
600, cbr, change, clutch, f4i, honda, install, installing, instructions, judder, jutter, replacement, spring, swap, walkthrough
