-   F4i - Main Forum (https://cbrforum.com/forum/f4i-main-forum-11/)
-   -   Changing Crankshaft. Can I remove the timing chain without removing the head? (https://cbrforum.com/forum/f4i-main-forum-11/changing-crankshaft-can-i-remove-timing-chain-without-removing-head-158189/)
Pmartone 09-09-2018 10:08 PM
Hello,
I am chaning a bent crankshaft. I have the engine out and I am about to split the crankcase. The last thing standing in my way is the Timing chain. Is there a way to loosen or remove the timing chain without removing the head? What should I watch out for? Will it throw the timing off? I need to remove it form the gear in the diagrams below and then everything can be split.
https://cimg0.ibsrv.net/gimg/cbrforu...fd90d68d13.png
https://cimg4.ibsrv.net/gimg/cbrforu...fd23452864.png
https://cimg5.ibsrv.net/gimg/cbrforu...ac28963608.png
SunBlue 09-10-2018 12:32 PM
You will definitely need to remove the cct and the head cover to take off camshafts but once you have the camshafts out the chain should come out easy
Pmartone 09-10-2018 01:03 PM
So there is no way to do this without the camshafts coming off. I'm trying to avoid disrupting the timing. Any words of caution?
Thanks,
Pat
74demon 09-10-2018 01:09 PM
By removing the chain and crankshaft, you will already be disrupting the timing. Just make some marks at tdc so it goes back together correctly.
when you get the chain off the cams, put them back on to hold your valve shims in place. This would be a great time to check the valve adjustment and correct as needed.
boredandstroked 09-10-2018 07:27 PM
Cams actually out or not your timing will be off. If you can split cases you can easily set cam timing.
