demon87 |
11-06-2010 11:41 PM |
okay well new update... i put the stock springs back in and in goes into gear now, BUT... it drags because the clutch is catching with the lever pulled all the way in. i double checked the cable routing (its routed from the lever, thru the forks under the top post, thru the frame to the bottom bracket) the cable is ajusted as far out as i can on the lever and to the very end on the bottom bracket. i even went as far to try bending the bracked farther away from the housing lever thingy lol it seems to catch less and go into gear easyer but still no cigar... so to say.. i soaked the clutch in oil over night before i installed, double check the cable to make sure its the right one, it goes thru the gears with the bike off so i know its not the tranny, oil is between the lines on the sight glass, no damage on the slider pin in the clutch housing, the lever thats on the clutch housing is connected to the slider pin, no kinks in the cable... so idn... this bike seems to be more tempermental then the F-18 i used to work on.. and i dont have money to take it to the mech. nor do i believe in paying for what i can do myself... but im stuck and gettin no where
