Change pedal rubbing and getting caught on the stand spring
Old 04-12-2014, 05:40 AM
cbr600-michael's Avatar
Default Change pedal rubbing and getting caught on the stand spring
I've started having issues with my change pedal rubbing on the rubber of the stand spring when I down shift. Some times I have to scoop it back up manually. What do I need to adjust to correct this issue?
Old 04-12-2014, 10:21 AM
Scott91370's Avatar
Look for a bent shift rod or bent pedal.
Old 04-12-2014, 02:33 PM
romoses4's Avatar
Also, check to see if your kickstand is loose or bent. The most common place for the kickstand to become distorted is not actually the kickstand itself but the "U" shaped tabs through which the pivot bolt for the kickstand runs. If these become too worn, they will allow too much free play in the kickstand.
Old 04-12-2014, 04:40 PM
I'll check into those when I get home tonight. I was able to make a course adjustment to the pedal height and it doesn't hit. I just have to get use to the different shifting style that is required.
krash
How-To: Mechanical
11-15-2010 07:46 PM
dyracuse
02-16-2010 07:11 AM
SpecR
05-15-2008 02:14 PM
clovisrider
04-21-2005 02:18 PM
Quick Reply: Change pedal rubbing and getting caught on the stand spring
