Chalk one up for the F4i
Old 06-26-2008, 04:06 AM
Aken's Avatar
July 2008 ROTM
Default Chalk one up for the F4i
3 - 0 in private road drag races tonight against 600s - 600RRs, newer GSX-Rs, other F4i, etc.. Also a couple wins doing some freeway races starting at 60+ against an RR.
It's nice surprising people =) Especially since I have no decals on the bike, so the guys who don't know me had to ask what I ride, lol. In all fairness, there was an 06 GSX-R that probably would've taken me if he raced. Similar mods but custom tune. And 1ks still walk all over me in a straight line, haha.
In case anyone cares, my go-fast bits include -1/+1 520 kit, K&N air filter, Bootleg Pipe, PCIII w/ Two Bros map.
Old 06-26-2008, 08:43 PM
axsys's Avatar
Default RE: Chalk one up for the F4i
i have almost the same setup as you Aken. i guess ill have to see how my bike does know that i have a benchmark......
Old 06-26-2008, 09:43 PM
dave ls1's Avatar
Does it feel any faster than stock?
Old 06-27-2008, 02:00 AM
Aken's Avatar
July 2008 ROTM
I can't really judge too well on that because I did most of the mods on down time, so when I rode it again it had been a while and I couldn't compare to how it felt a few hours prior. The sprockets were definitely a noticeable change in torque, though. I'm looking forward to getting it tuned sometime this summer.
Old 06-29-2008, 04:49 AM
f4ez's Avatar
im thinkin bout go 1+ 2- how much of a diffeence does that make?
Old 06-29-2008, 03:59 PM
Aken's Avatar
July 2008 ROTM
You mean -2 in the front, +1 in the back? BIG DIFFERENCE. Plenty of low-end torque, but your gears will be shorter, you'll cruise at higher RPMs, your speedometer will be whack, and your top speed will be like 140.
Old 06-29-2008, 08:55 PM
StrikeAnywhere's Avatar
Good topic for me right now,
If I want to get a little more low end power/acceleration but want to avoid taching to high when on the freeway should I avoid sprocket changes totally? I'd like to go -1/+1 but my stock F4i already hits about 6500 cruising 75-80 mph.
Would staying stock in the front and going up one in the rear even make an acceleration difference?
Old 06-29-2008, 09:10 PM
rolandk's Avatar
ORIGINAL: StrikeAnywhere
Probably notgonnanotice muchdifference. If your chain and rear sprocket are fairly new,try popping in a -1 frontsprocket and see how you like it,they only cost $30-$40. Gearing is always a trade off but IMO a -1 front is a pretty reasonable balance.
Old 06-29-2008, 09:39 PM
f4ez's Avatar
i meant one down in the front and 2 up in the rear how far off will that throw my speedo
Old 06-29-2008, 09:45 PM
jimd2p's Avatar
Throws it off pretty well. Also, you will cruise at a higher RPM. I always catch myself looking to shift one more gear. I added a speedo healer and all is well.
