Chain size/type
Hey guys,
It's time for me to replace my chain on my '01 f4i and I've run into a wall and I'm hoping you can help me out. What brand, size and type chain do you all recommend? Thanks, Jeff |
D.I.D. 525
Its what Honda put on it and works well enough. But any name brand should be fine. |
I recommend the search button.
You should know that it is recommended to replace the sprockets as well. Worn sprockets will accelerate wear on a new chain.
Yea, replace the sprockets with the new chain. I went with a BikeMaster 525 Xring chain. For stock gearing you'll want 108 link chain
If you are interested in weight savings and rotational mass, aluminum sprockets and a 520 chain. If you are like me and want a $200 investment last. You want steel sprockets and 525 chain. A thicker heavier chain will last longer. Just a suggestion, go down 1 tooth in the front. It will give you a noticeable difference in acceleration without killing your top end.
Did a search, found nothing and decided to bring back an old thread.
If my sprocket setup is 15/46 then what chain length do I use? |
