Chain Lube Maitenance Help
RE: Chain Lube Maitenance Help
they really say to use gear oil? thats weird.
chain lube is what you want, they are all aound better than oil.
do it right and wipe down the outside of the chain of exess lube, you only want to lube the pivot points, it will minimize fling.
remove the fling with rubbing alcohol.
I usually clean my chain with WD-40 first (what the dealer recommended---works great to clean the chain). Wipe it dry, then spray on chain wax (Honda stuff or equal to it). Wipe off the excess chain wax (if you want to minimalize fling-off). I usually lube my chain up real good and leave a little excess. My chain looks bright white when I'm done. Usually the chain wax doesn't fling off too bad (if any) when I put it on in excess. I feel better knowing that I have more than enough rather than not enough.
That's my two cents on the matter.
I found the following link to be very helpful. They should have all the answers you are looking for when it comes to cleaning/lubbing your chain. http://www.sportrider.com/tech/146_0208_geek/
cBrentb
04-25-2013 08:14 PM
