Chain Lube
Old Jan 6, 2010 | 06:21 PM
F4ith's Avatar
Default Chain Lube
Just wondering if anyone has tried Klotz KLR chain lube and can comment about it. I've been using it for a few thousand miles now and it always looked really well lubed and seemed to work really well, until recently. Their claim "quick drying" is right. I touched the chain literally 5 seconds after I lubed it and it felt dry/sticky. Is that how a lubed chain is supposed to feel? I clean my chain every 1000 miles and lube every ~330.
http://www.webbikeworld.com/t2/motor...lr-chain-lube/
Old Jan 6, 2010 | 06:48 PM
yog182's Avatar
Is it wax or oil?
Old Jan 8, 2010 | 05:07 PM
F4ith's Avatar
I'm not really sure. The can doesn't say anything about wax. It just says chain lube.
Old Jan 17, 2010 | 12:51 PM
backroad's Avatar
Sounds like a chain wax. I use Maxima Chain Wax and it dries to a waxy coating in a few minutes. With modern o-ring, x-ring, "whatever"-ring chains, they are internally lubed when they are manufactured. The o-rings keep the lube sealed in the links. Every 500 miles or so, cleaning the chain of dirt and applying lube or chain wax keeps the o-rings in good condition and prevents the chain from rusting. Chain wax has the added advantage of forming a seal over the o-rings to keep dirt off them, extending their life and therefore the life of the chain.
Old Jan 19, 2010 | 03:00 PM
JustinNck1's Avatar
I use Royal Purple and it seems to reduce my chain noise. I really like it. Heres the info on it.
http://www.royalpurple.com/chain-lubricant.html
Old Jan 19, 2010 | 05:41 PM
Zero1080's Avatar
How does riding in the cold affect chain lubrication? Should it be done before riding? After? And should it be cleaned and re-lubed after riding so it doesn't weaken anything.
Old Jan 19, 2010 | 07:09 PM
MC_spirited's Avatar
Well I imagine if the chain isn't lubed well then it will be more stiff. Possibly wearing your chain and sprockets faster? If you are riding on salted streets that is a different story, salt makes fasteners look ugly and damages some metals.
Naruku
Sep 11, 2009 06:14 PM
repyosol
Oct 29, 2008 08:29 AM
Cun0144
Sep 5, 2008 11:24 AM
CRAZY_600RR
Jul 17, 2006 07:00 PM
