Chain Lube
Chain Lube
Just wondering if anyone has tried Klotz KLR chain lube and can comment about it. I've been using it for a few thousand miles now and it always looked really well lubed and seemed to work really well, until recently. Their claim "quick drying" is right. I touched the chain literally 5 seconds after I lubed it and it felt dry/sticky. Is that how a lubed chain is supposed to feel? I clean my chain every 1000 miles and lube every ~330.
http://www.webbikeworld.com/t2/motor...lr-chain-lube/
Sounds like a chain wax. I use Maxima Chain Wax and it dries to a waxy coating in a few minutes. With modern o-ring, x-ring, "whatever"-ring chains, they are internally lubed when they are manufactured. The o-rings keep the lube sealed in the links. Every 500 miles or so, cleaning the chain of dirt and applying lube or chain wax keeps the o-rings in good condition and prevents the chain from rusting. Chain wax has the added advantage of forming a seal over the o-rings to keep dirt off them, extending their life and therefore the life of the chain.
I use Royal Purple and it seems to reduce my chain noise. I really like it. Heres the info on it.
http://www.royalpurple.com/chain-lubricant.html
cBrentb
04-25-2013 08:14 PM
