CCT Question
So I bought a new cct for my F4i and my friend was playing with it and took the key out before it was in. Soo do I need to get a new one or can you back it out again? Thanks
RE: CCT Question
Just stick the key in and wind it all the way to retract the cct lifter and lock it with the key.
This is a great opportunity for you to play with the thing and see how it works! It can be released and rewound many times without any problem. |
RE: CCT Question
Whew thats good news. I wasnt looking foward to dropping another 60 bux on one.
RE: CCT Question
If you can, tack weld the tip to the shaft....that is the main reason CCTLs tend to make noise....
RE: CCT Question
psss....i can't remember who came up with the welding the tip thing but dude...if you're going to do it make sure that ****e never ever falls off because it goes straight to the motor....
RE: CCT Question
ORIGINAL: Tahoe SC psss....i can't remember who came up with the welding the tip thing but dude...if you're going to do it make sure that ****e never ever falls off because it goes straight to the motor.... |
RE: CCT Question
from what i remember, once you pull the pin out you have like 7 or 8 seconds to throw it.
did you throw it? muhahahhahah |
RE: CCT Question
I threw it at his head afterwards
| All times are GMT -5. The time now is 07:47 AM. |
