CCT manual: APE vs Others
Old 02-13-2016, 04:46 AM
Default CCT manual: APE vs Others
Hi guys
Today I decided to buy one CCT manual cause mine have dead, or is close
I was looking in ebay the famous APE and I saw this other one, 1/2 less $$$
CNC Manual Cam Chain Tensioner Red for Honda CBR 600 F4 F4i 99 00 01 02 03 04 06 | eBay
any opinion? is better to install the ape one because this is worst?
thank you
Old 02-13-2016, 07:23 AM
Mattson's Avatar
It is essentially a lump of metal with a bolt going through. I`ve never heard a manual CCT fail, no matter what manufacturer. Basically the only thing that CAN fail is if you overtighten the securing nut stripping threads off the bolt. If the sealing surface that goes against the engine is even somewhat straight it shouldn`t matter if you made one yourself.
Old 02-13-2016, 09:04 AM
Conrice's Avatar
This.
Hell, a lot of people make their own.... Just make sure to use an o-ring around the bolt where it meets the housing to avoid oil leaking. It has one on there, but use a good one
Old 02-13-2016, 04:38 PM
Googling I've searched different models
do you think is important how much bigger is "the head" of the tensor?
I don't know if one is better than other, ofc if I ask to sellers they are going to say me that their are better
the second is bigger and have less contact with the chain when is touching because is not a plane, like the first one, that all surface is touching the chain
thank you very much
Old 02-13-2016, 04:52 PM
sjona2011's Avatar
the bolt actually never, well Should never, touch the chain. It pushes against the guide that the chain rides on so the thinkness of the end shouldnt make a huge difference.
Old 02-13-2016, 05:05 PM
Mattson's Avatar
^ That. It doesn`t make any difference as the the end will not be in direct contact with the cam chain itself. What matters is that you take the correct steps in fitting and adjusting the new manual CCT.
It goes around this:
-Remove the old CCT
-Wind the bolt of the new manual CCT back , to be sure wind it back all the way as it goes although it is not necessary
-fit the new manual CCT
-wind the bolt of the new manual CCT as far in as it goes with your fingers only. apply some force but don`t break your fingers.
-Start the engine. It will probably rattle like hell.
-Let the engine idle, wind the bolt of the manual CCT in enough for the rattle to end. Find the place where it stops rattling and then tighten anoter quarter turn.
-Tighten the securing nut while holding the main bolt in place.
-Refit fairings.
Old 02-13-2016, 05:14 PM
thank you very much
I didn't know about this system, I dont know much about mechanic, but yes, I've read it in the manual service and is true, this bolt push another part that guides the chain
spo I think I am going to buy the cheaper, because I dont know why is the double the other, maybe pay the brand, i dont know
Thanks to Mattson for steps, thank you very much to all
Old 02-15-2016, 12:54 PM
The ebay one is a cheap chinese lump of metal. I'd spend the extra for piece of mind and to not support china.
clockworkcbr
12-26-2007 09:13 PM
Blue70
11-01-2005 03:52 PM
F4iDanger
10-24-2005 06:43 PM
Quick Reply: CCT manual: APE vs Others
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
