CCT came loose while riding
Old 04-14-2017, 02:51 PM
Default CCT came loose while riding
This is a tale of tragedy stupidity and impatience.
-Background I am a 23 year old with little mechanical experience, with limited tools and space. I do oil changes, change brakes, and that's about it.
I had bought my F4I about two months ago, and when riding I noticed a certain noise. It only would appear while in gear, and at 5.5-6.5k RPM. Which was annoying especially when on the highway in top gear. But above or below it sounded just fine and no performance issues at all.
It was in this thread that I read and decided to buy a manual CCT.https://cbrforum.com/forum/f4i-main-...roblem-128703/
This video portrays the same sound that I had.
-Install
I went with the lazy way to install a cct using this method where you use a 45 degree attachment with allan keys and sockets. Everything went to plan except for tightening the locknut
F4i CCT Swap - pictures/directions - BARF - Bay Area Riders Forum
-Problems
For whatever reason I disregarded the term locktite. It didn't even register in my head. One, because I never heard of it before. Two, I guess I assumed I read it as "tightening the bolt" and never thought it of anything.
In the tight amount of space to install(lazyway) I have no idea how anyone can fit a 14mm wrench and tighten up the locknut of the cct. I would mange to get a 1/8 turn here and there after hand tightening it.
-Pre Incident
I rode my bike to test and see if the sound went away. It had not. I had tried researching the issue, but all I would get is people mentioning ccts, valve clearance, or it is normal and its just Honda's vibration and hitting a certain frequency. I decided what the heck its fine, and didn't peruse that issue.
I rode my F4I about 3 or 4 times at this point.
-Incident
It was nice out and decided to go for a short ride. no more than 30 minutes.
I was on my way home and on an highway exit to head home when I heard a terrible clatter. The CCT had become loose and I was really close to my house, so i said screw it and rode no more than 5 minutes to get back home.
I tried re adjusting the cct and seeing if I got lucky and the cam chain survived being loose, but after starting it up there is a new clattering sound that ive never heard before.
Now I am at a crossroads. One, I don't have any knowledge on rebuilds or have the tools for that matter. So I wouldn't know where to begin diagnosing the new problem. Two I don't think I can afford to take it to a shop right now/they wont look at it till winter.
TLDR:
CCT came loose, probably caused damage because bike doesnt sound good. Im sad/frustrated because spring is here and I could be riding so this is just a rant.
Old 04-14-2017, 06:46 PM
heyyou82's Avatar
Only thing I can think is draining your oil and opening up your clutch cover and you can at least see the bottom 1/4 of your cam chain and see what condition it is in. You can then rotate it until you see the whole thing. Once you take the clutch cover off though you will have to put new sealant on when you put it back on.
Old 04-15-2017, 05:28 PM
Thanks for the input. Ill give it a shot if i can next weekend and see what happens
Old 04-17-2017, 12:36 AM
If your manual tensioner is in now, were you able to tighten the bolt up to feel the resistance? before backing off?
Old 04-17-2017, 03:07 PM
Do you mean when I originally installed it? or after it got loose when riding?
Because yes I was able to tighten it up and back it off 3/4 turn before and after.
Update: Also l decided to loosen up up the tensioner, adjust the timing like this, and re righten the cct https://www.google.com/search?q=f4i+...hcMmFzhQx58cM:
Now The bike sounds fine again. But I am still worried that I may have caused damage during that loose cct ride. (it was about 5 minutes of ride time).
Anything I should do? or do you think it is okay to properly install the cct and give it a go?
Old 04-17-2017, 03:12 PM
You're issue would be if you caused to to slap around whilst riding those last 5 minutes.
If you adjusted your timing, it will depend on by how much as to the potential for how much damage you might have caused.
Only way to tell will be a chain inspection per the previous poster, but at least it sounds like you've gotten it running smoothly again.
Old 04-19-2017, 08:03 PM
Personally, I'd be using this as an excuse to tear everything down and do valve clearances. That'll give you the ability to inspect the chain and gears better to be sure. You don't want to mess around with this.
cycle.tim
09-08-2012 08:50 AM
woodypk
03-06-2011 12:41 PM
drprcbr
12-12-2006 10:38 PM
Cali_rider600
10-06-2006 04:09 PM
arod1320
05-02-2006 01:23 PM
Quick Reply: CCT came loose while riding
Featured Sponsors
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
