CbrF4i wont start, think it is fuel injector but not sure
I have a 2002 Honda cbr f4i, its my first bike and I don't know much about it. I was driving with my friends playing when I hit a speed bump going pretty fast and it just cut off and won't start back up. After reading I think it has something to do with the fuel injector because when I try to start it up I hear silence when I turn my key when I use to hear a sound when the rpm needle went up and down. I tried to pop the clutch for a hour or two but it will sound like the engine rolls two or three times and dies like it doesn't want to catch. All the lights and everything work fine. Once again I don't know much about bikes and would like anyones opinion and advice, I would appreciate it so much. I have just recently changed the battery so I'm counting that out. Thank you again.
RE: CbrF4i wont start, think it is fuel injector but not sure
if you turn the key on do you hear the fuel pump prime? theres a senor on the headlight (tip over sensor) check the conection on that. than i would check the two big plugs on the cdi (the computer on top of the battery) and make sure they are pluged in good. hope it helps and good luck
ORIGINAL: imthabiz
Thank you for your reply's, you were exactly right. It was the fuse to the bank angle sensor. Thank you sooooo much
ORIGINAL: StreetPower
if it happens again, i would recommend you to find an instruction on deleting and shorting out the bank angle sensor
ORIGINAL: imthabiz
C Jacob W
07-29-2013 11:03 AM
