Can headlight bulbs be replaced without removing
I did not need to remove the upper cowl to replace the headlight bulbs on my 2001 F4i. It only took 4 minutes to replace them both. Please refer to page 19-4 (pg. 464) and 19-5 (pg. 465) of the 2001 - 2003 Honda CBR 600 F4i Service Manual.
It says to:
1. remove the air duct cover.
2. release the resonator chamber from the hook arm.
3. disconnect the headlight bulb connectors.
4. remove the dust cover.
5. unhook the bulb retainer and remove the headlight bulb/socket.
*If you touch the bulb with your bare hands, clean it with cloth moistened with denatured alcohol to prevent early bulb failure. *
6. remove the headlight bulb from the socket.
7. install a new bulb into the socket.
8. install the new headlight bulb/socket aligning its tabs with the groove in the headlight unit.
9. hook the bulb retainer into the headlight unit groove.
10. install the dust cover tightly against the headlight unit with its arrow mark facing up.
11. connect the headlight connectors.
12. hook the resonator chamber to the hook joint.
13. install the dust cover.
repeat for the other side.
It says to:
When you take your bike to the dealer, have them flush out your flux capacitor too. lol
The headlights can be changed without removing the fairing, but its easier to do to take it off. And you don't want to touch the bulbs with your fingers. The oil on your fingers can make the bulb explode. If your going to change your bulbs, put in an HID kit.
