Calipers For 2001 F4i
Hi
I was looking at changing my calipers to the 03 600RR ones just for some gold bling. After reading on here i see 929/954 Blade calipers also fit. They look the same but are the brakes from the blade any different in any way or did they just put them on the 03 RR? I had read on here that the blade brakes were better due to some different internals so wondering if they are what the used on the 03 RR?
Thanks
GT
Thanks
GT
they are the same, i dont think they are really any better, prolly not any better to make a huge braking difference, cheapest route wuold be to paint your f4i calipers
one other thing, they could be slightly different, like the rear on the rr is a mirror image of the f4i's the banjo bolt goes on the opposite side and stuff like that-so your brake lines would run into issues
OK
Thanks guys, prob try and get some 03/04 calipers as i cant be bothered painting them (lazy i know) and will look better than if i do em. Just picked up a rear 04 rr one on the bay for £14 with master cylinder so cheap as chips. My rear is pretty goosed anyway. Will the rr front MC fit and be any improvement??
Cheers
GT
Cheers
GT
it will fit but is the exact same thing pretty much. get a radial one if u want improvement, but it will more just be feel than braking power
and make sure u stay with those years bc the newer ones are radial and the radial calipers will not fit, but the radial master cylinder would be fine
