Calipers For 2001 F4i
Hi
I was looking at changing my calipers to the 03 600RR ones just for some gold bling. After reading on here i see 929/954 Blade calipers also fit. They look the same but are the brakes from the blade any different in any way or did they just put them on the 03 RR? I had read on here that the blade brakes were better due to some different internals so wondering if they are what the used on the 03 RR? Thanks GT |
they are the same, i dont think they are really any better, prolly not any better to make a huge braking difference, cheapest route wuold be to paint your f4i calipers
one other thing, they could be slightly different, like the rear on the rr is a mirror image of the f4i's the banjo bolt goes on the opposite side and stuff like that-so your brake lines would run into issues |
929 entire front end conversion FTW!
Originally Posted by Sick97SS
(Post 916308)
Like vang said.. same calipers... just go get some gold caliper paint and call it a day... |
OK
Thanks guys, prob try and get some 03/04 calipers as i cant be bothered painting them (lazy i know) and will look better than if i do em. Just picked up a rear 04 rr one on the bay for £14 with master cylinder so cheap as chips. My rear is pretty goosed anyway. Will the rr front MC fit and be any improvement?? Cheers GT |
it will fit but is the exact same thing pretty much. get a radial one if u want improvement, but it will more just be feel than braking power
and make sure u stay with those years bc the newer ones are radial and the radial calipers will not fit, but the radial master cylinder would be fine |
errr i was thinking tokyo calipers. i got all excited...
lol sick im thinkin on putting r6 disks on my vfr wheel ;-) thinkin about r6 calipers but ide have to measure for fitment issues first lol
Thanks for the advice guys. Can you tell me what size the F4i and 600RR MC's are? Also if i want the lever to have a firmer feel do you need smaller piston with longer stroke? Slightly confused about master cylinders.
get ss lines and a radial mc and bleed it really good, itll be nice and firm
