busted exhaust stud
Welcome to the forum, what a pain that is.
https://www.partzilla.com/product/ho...05bd0dae76ccf8
8x24, remember that the diameter is smaller on the stud end.
Lets see some pics of our ride.
There are 3 bolts holding it on, two at the top and one in the middle at the bottom as per the attached:
https://www.partzilla.com/catalog/ho...radiator-01-06
You should be able to tilt it out of the way with just removing the lower bolt if that gives you enough access. The cowl does not have to be removed.
