brake rotors
RE: brake rotors
The rear rotor will pick up more dirt and debris than the front, and therefore you will end up with more scoring of the rotor surface through regular riding. My general opinion is that even if the rear rotor is totally shot (e.g. under spec thickness, warped, scored, etc) it will still work as long as you have pads, and pulsation under braking isn't as much of an issue... in fact it's sort of like free ABS, in a bastardized sort of way.
On my old SV, I was using an F3 rear rim, and that thing still had the original OEM rotor on it... it was so badly grooved, at first it wouldn't provide any braking even under load from the rear caliper. Eventually the rotor broke in the surface of the pads so that they mated properly, and I regained braking. Since I wasn't using my rear brake that much, it didn't bother me. If you're a heavy rear braker, you just need to know that it takes a while longer for pads to break in if they're mated to a rotor that has an uneven surface.
the blonde weasel
the blonde weasel
RE: brake rotors
Just remember a coouple of things when you have to change your rotors,
1. change it with a tire so the wheel is properly balanced.
2. always change your brake pads (no matter how much pad is left) when changing rotors, because the old grime, dust and wear pattern will score the new rotor reducing its effective-ness
3. always replace the mounting hardware, these are a very critical fastener and ensure they are properly locktighted.
4. clean your caliper pistons/pucks while disassembling for the best possible stopping power.
good luck!!
good luck!!
RE: brake rotors
ORIGINAL: redbull95
good luck!!
good luck!!
2- Not req'd
3- Locktite yes, replacement not req'd
4- Of course
You Sir, must be an auto mechanic. I'd say European autos???
RE: brake rotors
ORIGINAL: redbull95
good guess!but what I work on isn't that reliable (I wish) I am a Service Advisor for Harley.
But hey at least you have a job in the M/C industry, right???
RE: brake rotors
ORIGINAL: travsstuff
Harley has a factory in Kansas City right???.....thats where I am from. You by any chance from KC???
ORIGINAL: redbull95
good guess! but what I work on isn't that reliable (I wish) I am a Service Advisor for Harley.
