Brake Fluid specifics???
RE: Brake Fluid specifics???
ORIGINAL: Jaybird180
Yes that is correct. 3 and 4 are not compatible. 5.1 is synthetic 4.
i could have sworn i just answered a question like this. Yes its dot 4. Dot 4 is reverse compatible with dot 3 but not the other way around. If you have a dot 3 system you can use dot4 if you have a dot 4 system you CAN NOT use dot 3. But our bikes are DOt 4 so this is all irrelevant. Just get the small bottle it will fill front and rear multiple times.
I recently learned of a great way to bleed brakes. Works better than anything I've tried.
Forget the speed bleeders. Go on e-bay and find a large medical/industrial syringeabout 60 ml will work. They're cheap so buy several. Put a clear hose on the syringe about six inches long and draw all of the fluid out of the master cylinder reservoir and discard it. Fill the syringe with fresh fluid, open the bleeder valve and force the fluid back into the reservoir from the caliper end. Repeat as necessary.
This works so well that it really changes the feel of the brakes and a hydraulic clutch, if you have a bike with one of those. (Not on the CBR, but my Aprilia has one.) Here in Florida, brake fluid loads up with moisture and has to be flushed at least once a year.
Paul
Paul
