Blinkers effect displays?
I just put on my flushmount blinkers and now my tach and my screen are not functioning... any relation?
RE: Blinkers effect displays?
Only thing it might affect is you might have blown a fuse in the process. Not sure how you would've done that, though - they should be a separate circuit. Check it anyway.
Fuse, funny thing is when i installed my lights, same thing happened;)10A i believe
You're all doing something wrong if you're blowing fuses installing a set of blinkers, lol.
lol, wires touching metal - not hard to do, plus my hands are huge:D
that's why you should disconnect the battery...:)
;)yep good, one. Also when your turning your ignition on and off to check lights for eg lol, just remove the 10A fuse for lights, it will save your battery, doesnt take much to drain it
