-   F4i - Main Forum (https://cbrforum.com/forum/f4i-main-forum-11/)
-   -   Black Bolts (https://cbrforum.com/forum/f4i-main-forum-11/black-bolts-101878/)
yog182 10-06-2009 03:17 PM
Black Bolts
Hey guys, has any one seen a fairing bolt kit that was black? I have seen the spiked ones and that just aren't my cup of tea.. I have tried Ebay and Google with little to no success.. Anything would be helpful at this point..
Thanks
Incognito 10-06-2009 03:27 PM
If I were you, I'd scuff the heads of the bolts with fine sandpaper or steel wool, and stick them through a piece of cardboard, so only the heads are exposed. Paint them with a bake-on ceramic finish (engine block paint). I've done several projects that way on high wear items, and the finish is as durable as you're going to get anywhere. Just a suggestion.
yog182 10-06-2009 05:21 PM
That sounds cheaper then a bolt kit =).. Im liking it so far.. Any other suggestions or links that i can look at?
Zero1080 10-06-2009 07:02 PM
Go to Advanced Auto Parts, pick up DupliColor engine paint. Resists up to 500 degrees and personal experience has had it up to 520. Just paint the heads, and you're good to go. Takes about 5 minutes to dry, 8-10 for 100%. Cheap and easy.
Speeding 10-06-2009 08:09 PM
bikebolts.com sells them in black, or just about any color you want the heads to be. But it is $10 more for color heads.
I would suggest following Incognito's advise though and just paint them with a bake on coating, will look just as good and last just as long. If it doesn't stand up to your liking, you can re-coat them or just go and buy some.
silverstonef4i 10-07-2009 04:34 PM
1 Attachment(s)
so being unemployed i liked this thought and went ahead did it today... took the bolts off wired brushed them and used high temp stove paint..here is how they came out.. i like them and will be doing most of my bolts this way
Zero1080 10-07-2009 06:53 PM
^Looks great. I have a silver and red bike, so to paint them black, would be odd.
Kevin48 10-07-2009 07:19 PM
Im pretty sure I just saw a set on Ebay for about $50. I know they have the spiked ones, but I saw a whole set in black the other day without spikes
Jerzdan 10-07-2009 09:40 PM
This is going to be my next mod for sure... I think it will look pretty good with my blue and black paint scheme... Thanks for the idea guys.
Aken 10-07-2009 10:06 PM
http://www.bikebolts.com
