Bike wrapup
Old 06-06-2017, 08:19 PM
xifer's Avatar
Default Bike wrapup
Edit- i've got the bike apart- i've settled the radiator issue, but now a electrical issue popped up.
So ive got my f4i apart right now with the tank up the throttle bodys exposed and the airbox aside this is because company sent me the wrong throttle cable and im waiting on the push cable- then my radiator is off and im wondering what connects to the connector on the radiator that is 1 pronged ive looked everywhere.then i need to re wire my headlight plugs because i snipped them when i tries to wire in a streetfighter light- then mountin
g and making a diy anti rotation pin for the left switch then putting on the left grip . Any help ?
also theres no oil and hasnt been for about a week should i put some in while its sitting? - edit put some more rotella t6 in there - 3.5~ ish quarts
Old 06-06-2017, 10:11 PM
SunBlue's Avatar
The only electrical connection I remember on the radiator is the fan switch on the left side... but I may be wrong, it's been a while...
Old 06-07-2017, 05:11 PM
boredandstroked's Avatar
Yeah I'd go with radiator fan wire.
Old 06-07-2017, 06:51 PM
xifer's Avatar
what fan wire? i dont see anything that can connect to the metal prong
Old 06-08-2017, 09:48 AM
rfesu's Avatar
it has an angled black rubber boot on it, and runs through the same harness as the fan connector.
here's a googled picture
http://zeus-armor.com/home/wp-conten...ator-Cage2.jpg
Old 06-09-2017, 10:56 PM
xifer's Avatar
I dont have a rubber boot for it to go on, so it means nothing connects to it ?
the connector is just meant to be screwed into the radiator?
Old 06-09-2017, 11:40 PM
Can you post a pic of what you have? That will help tremendously.
Old 06-10-2017, 12:39 AM
xifer's Avatar
from looking at the plugs themselves there isnt any obvious wear or non connection.
Old 06-11-2017, 10:28 AM
Have you thoroughly cleaned all the contacts on both sides of the plug?
Old 06-11-2017, 08:12 PM
xifer's Avatar
EDIT: i cleaned both sides of the connector with contact cleaner... still only two dashes showing up on display instead of the time... WTF I cant find any info about this anywhere, how do i set the time???
