Bike won't start helppp
Heyy guys i just changed my battery like 3 weeks ago and my bike was running fine, i probably haven't started it for about a week and tried today and now it won't even power on or crank. I installed a security system, could this have drained the battery? or could it be another problem?
If there is no power to anything then I'd guess that something is draining your battery (like the alarm) or your R/R went out. If your gauges light up fine and then reset when you hit the starter, then your FPR coulda went bad and proly hydrolocked your motor. But I'd bet its electrical. Whatever you do DONT jump start it with a running car.
And my LED remote has taught me this lesson as well.
P.S.
Also, where do you live? Cold temp will affect your battery negatively as well. Before assuming anything is majorly wrong, take the battery and throw it on a charger. If it cold outside, let the battery warm up in the house overnight before doing so. A charger may incorrectly diagnose the battery as having a dead cell if the battery is extremely cold.
No gauges light up or anything i just see two A A signs on the bottom when i turn it on, than it disappears and nothing. ill check my battery first i suppose.
If it is my alarm draining my battery can i get rid of this problem by just starting the bike daily so the battery won't be as drained by the alarm? i heard batterys need to be started daily or they die.
There's some debate on this but simply idling the bike won't charge the battery. Some say it will but most state the bike needs to rev higher for the stator (motorcycle alternator) to produce enough excess power to charge the battery.
You'll need a battery tender to keep the battery charged if it's not being actually run over long periods. I'm guessing your bike isn't stored in a garage and whereever you are, the weather is too poor for daily riding. Hence you wanting to keep the battery in and the alarm running.
Okay ill look into getting a tender. and yes it's stored in a garage and the weathers been nice, i live in hawaii. BUT i just took my MSF course and am in the process of getting my license and insurance so i can finally ride LEGAL so i took a month off. and i cant turn my alarm off, if i disarm it it rearms itself in 30 seconds.
