Bike won't start
First go here and download the manual hondatech.info: Honda service manuals
then try this:
page 5-53
FUELPUMP
INSPECTION
Turn the ignition switch ON and confirm that the fuel
pump operates for a few seconds.
If the fuel pump does not operate, inspect as folIows:
Open and support the front end of fuel tank
Disconnect the fuel pump 3P (Black) connector.
Turn the ignition switch ON and measure the voltage
between the terminals.
Connection: Brown (+) - Green (-)
There should be battery voltage for a few seconds.
If there is battery voltage, replace the fuel pump.
If there is no battery voltage, inspect the following:
- Main fuse 3DA
- Sub fuse 1DA
- Engine stop switch (page 19-19)
- Fuel Gut relay (page 5-54)
- Engine stop relay (page 5-84)
- Bank angle sensor (page 5-83)
- ECM(page 5-85)
then try this:
page 5-53
FUELPUMP
INSPECTION
- Main fuse 3DA
- Sub fuse 1DA
- ECM(page 5-85)
