Bike will not start in first?
Bike does not start in first gear, clutch engaged, it acts like the kickstand is down. In neutral with kickstand up i can start and click down into first and no problems, bike stays on and is normal. its only if it is off and i try to start it in 1st gear. Bad kickstand sensor, or something else? where can i trace the kickstand harness to?
RE: Bike will not start in first?
clutch switch or neutral sensor might be bad. pull out the clutch switch wires, and check resistance with a multimeter. it should change when you press/release the lever. If it does, check the wiring harness. If everything is ok check the neutral sensor (does the light show up right?)
ORIGINAL: JeremyGSU
It's most likely your clutch switch. My bike did the same thing when I bought it. Took it to the dealer and had the clutch switch replaced and now the bike will start in first.
Is there any places to get honda parts online?
ORIGINAL: Leveltwo
what did this cost you?
ORIGINAL: JeremyGSU
