bike starts but wont run
RE: bike starts but wont run
AFter you start it, can you work the throttle at all, does it rev fine?
Do all your lights, signals, brakes etc work while it's running?
How about your gauges?
Probably some kind of electrical short somewhere. Anything happen to the bike before this started? Bad rainstorm or something?
yeah start it and try and rev it if it just dies out like wont rev try hooking your battery to a trickle charger for a couple days then hook it back up if it still does it try a new battery i recomend borrowing a battery you know is good from a friend and tryin that before you buy a new one, i had the same problem i start it and it would idle and everything but if i reved it it would just die out to much juice ot power the fuel injectors from the dead battery.
