bike not starting
ok guys this is the problem.i was rideing for about 20min stoped to put gas in my bike tried to crank it started then died. if the key was turned off the clock would work but if i turned it on everything went out. isthis just from a dead battery or could it be the alternator because,i tried to jump it and it would stay cranked as long as the cables was hooked up but unhook them and the bike dies.any help would be nice thanks
most likely a bad battery but you would need to run a volts test to be sure.
At semple idle I dont think that the alt is putting out enouph to realy do anything so You would need to rev it to like 2+k to check voltage output and amps. |
do batterys go dead that easy i haven't rode it in a week but itstays in the house so heat couldn't have drained it
yes a older battery can go dead like that.
finding out depends on how you ride. but like i said you would need the bike running on its own to test the alt. |
just in case it is the battery where is the best place to buy a battery for a 02 f4i from a dealer ship or off the net
Im a cheap Basterd I get Mine at wally world(Wallmart) :d
how much dothey run there because i talked to a guy at auto zone and it was 169 because it's a jel battery
ermm Have not got one for My 02 yet.
ok i found one from dennis kirk same thats on my bike for 98 bucks so thats better than 169 ill get that as long as its not the alternator or something
autozone sells them for like 65 bucks
