bike keeps dying....NEED HELP!!!!!!!!!
Old Jul 8, 2010 | 07:02 PM
Slydell19's Avatar
Default bike keeps dying....NEED HELP!!!!!!!!!
SO whenever i hit a bump now my bike keeps cutting out... also when i came to a stop and went to let out the clutch it died instantly. It runs perfectly fine in nuetral but when i put it in gear and go to let out the clutch it dies imediatly. Grounding Problem???????? i took apart the clutch and the two wires going to it inspected everything and tried to make it cut out and it wouldnt, put it back together and everything seems fine but i know that i didnt solve the problem.........
Old Jul 8, 2010 | 08:58 PM
evanb's Avatar
Check your kickstand switch. Obviously it's hard to diagnose without looking at everything but it sounds like the bike thinks that the kickstand is down, which would kill the engine if you're in gear.
Old Jul 8, 2010 | 09:00 PM
skoobydoobie's Avatar
I would initially say check the battery connections, and ground. But with the neutral dependant prob, its proly the kickstand switch, might be lucky and just be loose.
Old Jul 8, 2010 | 09:03 PM
HaHa, I'm pretty slow on this droid thingy
Old Jul 15, 2010 | 03:50 AM
ozf4i's Avatar
mate i had a very similar problem i ended up discovering it was my drop sensor, it was not perfectly upright because the bolt was loose,
have a check it may fix your problem, it drove me mad for a long time found it by mistake,
good luck!!
lawls
Jun 13, 2010 03:58 AM
fastratchet
Jul 28, 2009 06:04 PM
T rick
Sep 25, 2008 11:49 PM
catchx34
Sep 24, 2008 10:03 PM
