Bike cranks but no start!!
2001 cbr f4i Ok this has happen a few times now it wont start at all someone help. The bikes side markers stay on, the headlight and brights
dont work but the bright light indicator is on, it cranks over good but the fuel pump dont primp at all. If you hold the starter button down itll stay on. PLEASE HELP> |
RE: Bike cranks put no start!!
The ground connection in your headlight assy might be loose. Look for it in the service manual at stephygee.com
i have the same prob. wiggle the headlight/gauge cluster harness/connector. sometimes it'll get a bad connection (god only knows why). you'll hear the fuel pump prime and the lights will go off.
the harness/connector is on the left side of the bike thru the front-most opening in the side fairing...right about parallel to the top left corner of the radiator |
a picture is worth a thousand words...
http://oak.cats.ohiou.edu/%7Evp230799/bikefix1.jpg http://oak.cats.ohiou.edu/%7Evp230799/bikefix2.jpg http://oak.cats.ohiou.edu/%7Evp230799/bikefix3.jpg |
ding ding ding! we have a winner. good pics flyou
CCTL
FPR Map Sensor and this are some of the more common problems with the F4i |
Thanks for the replys and the good pictures im gonna check that.
FLYOU
what are you looking for bad on that connection, i looked and looks ok is there any voltage there at all. STILL WONT START! |
i hope not. that should be the ground pin(on the grey connector)
Hey Fly did you take your bike apart to take those photos? If you did TWO Thumbs up to you bro!
