Bike Bounces When Applying Front Brake
Hey guys! Got the old girl on the road and she's been a blast, save for the sporadic turn signals (seems to be a delay of 2 seconds before they turn on, but it works). I'm having a problem where applying the front brake even gently at low speed bounces the front end a bit, and it's kind of upsetting.
I think it's the rotors, based on what I've read. What's the course of action here? Sanding them a bit and using brake cleaner helped, but it's not perfect.
(I also have an issue where after riding for a while, my idle sits at around 15-1600 instead of the 1300 I have it set to. Blipping the throttle quick seems to fix this, so it's a relatively minor issue. Curious if the lack of O2 sensor on the bike is affecting it, or something)
You might have warped rotors. When you push the bike forward do you get a dragging sound and increased resistance which then eases off and comes back when a certain point of the brake rotor enters the caliper?
If it's more of a judder you might have worn steering head bearings. Pull the front brake on and rock the bike back and forth. Are you hearing and/or feeling "clicking" from the steering? That would be a telltale sign of that. Another sign is if the bike tends to "wander" left and right instead of wanting to go straight.
How old/worn is your front tire?
If your brake discs are in fact warped you need to replage them. Sanding will do nothing to the problem and bike rotors are not thick enough to be turned straight in a lathe. A new set would probly be cheaper anyway.
If you end up replacing your discs I'd advice to stay OEM. they're more expensive than those aftermarket snowflakes, or "gingerbread discs" as we call them but be adviced many cheap aftermarket rotors may be already warped coming from the box.
My dad half heartedly confirmed he thought there might be a little something. I kept the pressure and method of spinning the wheel even, and would watch the little red "Diablo" text on the totally new front tire. Every time it reached a certain area in the rotation, the familiar "Phwoaaahh" of the brakes rubbing on the rotors would turn into "Phww" and it seemed like there was more friction, since it would neither spin as much or as easily as before. I'm always open to more in detail explanations or analysis, but it seems I'm getting close to the culprit.
Yuppers. Seems pretty much like a warped rotor(s) to me. If you want to be sure bolt the rotor off from the wheel and place it on something you know to be level like a glass pane, I`ll bet a section of it is elevated. Notice that the different is probly miniscule but that usually is enough. I`ve seen rotors so bent you can notice the wobble by just spinning the wheel fast on the stand.
Obviously goes without saying, before ordering any expensive rotors do verify that indeed is the culprit. I haven't seen the bike in person so I can only throw (somewhat) educated guesses at what could be the issue. But if the rotor/rotors are grabbing at one spesific spot then something has to be out of alignment.
Obviously goes without saying, before ordering any expensive rotors do verify that indeed is the culprit. I haven't seen the bike in person so I can only throw (somewhat) educated guesses at what could be the issue. But if the rotor/rotors are grabbing at one specific spot then something has to be out of alignment.
Thanks for the help!
